Driver side rear wing-window, stuck open(yesterday it was stuck closed). Is there a manual override to close the window...
Jstekk
Hillsboro Oregon
Have a 2003 Ford expedition 4x4 Eddie Bauer edition. My rear driver side Wing window is stuck open, yesterday was stuck closed. I need to find out whether or not it has a manual override. Please help because it's in the middle of winter. Please please help somebody... IMG_20231227_095020542_HDR.jpg
S20Workstation4
Hyde Park, NY
No, there is no manual override. I would try to CAREFULLY disconnect the mechanism (so the glass doesn't break), and manually push the glass shut. Then, i would tape the glass so that it stays shut, and try not to use it.
Do you know why it is starting to stick open/closed?
Hamfisted
Ft Lauderdale
The switches get corroded from lack of use. So you might be able to just get some contact cleaner spray from the autoparts store or Walmart and yank the overhead console down and unplug the switch and spray it out with contact cleaner. You can unbolt the window from the actuator arm and remove the actuator assembly and duct tape the window closed as a temporary fix till you can get the new actuator sent to you if need be. Try cleaning the switch first. If that don't work then grab a new motor/actuator assembly for about $50.
Gen2 Expedition Quarter Window Motor/Actuator Assembly Online
Rear Quarter Window Motor/Actuator Assembly .... Driver's Side
Jstekk
Jstekk
Hillsboro Oregon
I think it was condensation causing a short... I disconnected the wire and I used a wrench on the actual plastic part of the actuator to close the window... I didn't use any tape because I just didn't need any it's completely closed....
