OCJoeR
I've searched and read the other threads on this matter and haven't found one with a solution. I'm buying a '06 King Ranch with this problem. As best I can see from the posts and videos I've also watched there are 5 attachment points for the panel. Two on the bottom edge, 2 under a little pull out panel on the side and one on the inside edge of the rear of door. The problem is with the door closed I don't see a way to get to that last screw, the one on the inside edge of the door. I've read some of the threads where it was recommended to pull and push on the interior door lock rod until it tripped the opening mechanism so I'll try that once I have the truck. As best I can tell a slim jim isn't going to work. I'm wondering if there's a way to reach the child lock lever from the inside with the door shut. From one of the videos I've watched it appears to be a small lever that I might be able to move with a thin screwdriver if I can get it between the door and the door sill. I'll also try that once I get it home.
If anyone has any other suggestions or recommendations please let me know.
Joe
Joe
