Drivers Side Window and Exterior Door Hangle
Rogiecrockett
Iowa
Two things here in the same general area of repair:
Drivers side window - loose from the regulator. The window when going down gets sideways. I had repaired by a local auto shop that only lasted for a few months. Sick and tire of this problem. Is this an easy repair for a DIY?
I am prepared to buy a new regulator, just need to know how difficult these are to install.
Driver's side door handle - the Expy has a tendency to frost up in cold weather causing doors to stick when opening. I pulled the door handle yesterday and something gave. I suspect the linkage from the handle to the door gave. I see on some internet parts stores, the replacement costs under $15 - they are plastic. Hard to imagine they are quality for this cost. Has anyone ever replaced one of these or replaced parts in this assembly?
For both of these, my guess is the hardest part is pulling the door interior and electronics off.
R
Rogiecrockett
Iowa
Thanks - I found this on YouTube after I originally posted. This guy covers everything I think I need to do. Looks fairly straight forward.
Only issue is that if I cannot fix what I have I need to buy new and they seem to be black and not painted to the color of the exterior.
Not sure if I can purchase aftermarket to my color but will start to do some digging on that issue.
Thanks again.
Rogie
