What is the color temp on those, the bluer ones throw less light. Never saw any silver bullets with any of those.Also installed Sylvania SilverStar Ultras. Seems to be brighter and further throw than stock.
That dash looks somewhat like my '07 Navigator dash but the Navi speedo cluster is horrible, they put the numbers up to 140 mph and it's all dark in there so I can't see anything hardly, it's the worst part of the truck.
My mistake, I am used to looking at H I D bulbs lately because I had to replace mine.They are high output halogens, they just burn hotter than standard bulbs
I can deal will the squared off look but it's so dark in there I can't read the speedo with sunglasses on in the daytime. I can see the needle and if it points to the corner of the square frame that's 40 mph and I think straight up is 60.I wanted a navi of that gen but I can't get past that hideous cluster...they'd almost have to give me the car to tolerate it. I feel like they were like like, "Oh, here's some crap from the 70s, let's do it!"
I read where it is easier to remove the solenoid first to get the starter out, what do you think?Starter went out yesterday, replaced it this morning. Got the production spec one from the dealer.
How many hours did you put into the tensioners, guides and pump? You don't catch a break, do you?
I did it in 18 hours with no problems and you had tons of problems plus you took a lot more apart so there is no way you could have done that in 20 hours.I’d guess 15-20 hours if I threw a random number out since I had to do it twice after a mistake. It was doable just relatively difficult/ time consuming.
Looks like the biggest difference is the new pump has blind/closed holes for the bolts that hold the plate on the other side. It does have a plate of sorts on the opposite side that holds the guts in correct? The blind holes can’t leak around the threads and lose pressure.....Maybe????Cleaned up my old oil pump (Now a trophy) and found Ford updated the new one. There are various differences between Fords 2007 and 2020 built 3V pumps when I compared pics. Wonder if it’s just casting differences or if internal changes were made.
Original OEM:
New Service OEM Installed:
