Thermo
technical advisor
- Joined
- Apr 18, 2011
- Posts
- 1,407
- Reaction score
- 65
If you go with that setup from Amazon, you have to figure out a key thing, where are you mounting that big brass fitting in the coolant system? There is no real place for you to mount that in our trucks. So, you will still end up getting some sort of thermostat controller for the truck, which is the expensive part of the whole setup.
Also, that setup has a 180F thermostat associated with it (assuming you use what they provide). Our trucks have a 195F thermostat in them. So, the fans are going to start running before the truck is even up to temp and they are going to be running any time the truck is up near normal operating temp. This is a complete waste. This is a good setup for older cars (ie, 80's and such), but for our trucks, the purchase will be good for the harness and the fans, but that is about it. Then you have to figure out how to modify the system to make it work.
If you want to make this system work, let me know and I will see what I can do about finding parts that will make things a bit more "plug and play" for those that are not wiring savvy.
