Electrical Problem
ARiley23
So I replaced my dash lights with some leds and right after my power side view mirrors stopped working (fuses are good) and the headlight warning beeping noise when you open the door and the headlights are on will only come on when I have the panel dim set below a certain point. As well as the interior lights will not turn on when the panel dim is set at a certain level.
Any ideas? Thanks.
Bedrck47
Elizebethtown, PA
would suggest that you replace all the led's with regular lamps to be certain that wasn't the cause of your problem Or first recheck the connectors to see if you bent a pin
AbbadonTD
Colorado
So its probably an LED has its wire bent wrong. They are harder to install right than you would think looking at them, but if the wires are not right, they wont work.
