Just bought a 97 EB 4x4 with 189,000 miles this past Saturday (1/1/11) and there are some issues with some of the electrical stuff. I've looked at every fuse, and unless there is a fusebox that I haven't found, they all appear to be good. I did find a blown fuse for the Foglights relay so I got them working again.
1. The rear wiper does not work, but the rear washer pump does.
2. The rear window vents do not move on either side when you push the buttons.
3. The Cruise Control doesn't work.
4. The 4WD doesn't work. No lights light up on the dash when you turn the switch, and you can't hear any noises either.
Given that the fuses all look to be intact (visually checked, not with a multimeter), is there maybe a common plug somewhere that ties the rear wiper motor and vents together?
On the Cruise Control it appears that everything is connected under the hood.
Where do I need to start? The last Ford I owned was 1991 Festiva.
