2006 Expedition Limited w/ 187K miles.
Folks,
Yesterday I was driving down from Mt. Hood after skiing and using the O/D on/off occasionally to decelerate on the long declines. One time, on the flat, when I turned the O/D on the engine went into failsafe mode. I shifted into neutral, the engine died, but I was able to pull off. I restarted the engine with no apparent problem, nor any error lights on the dash. We drove home. Today, I went to back it out of the garage like I usually do--in neutral with a little push before I even turn it on. While rolling back, I hear a slight grinding sound that appears to come from the front end. Once out of the garage, I put it in park and look for anything obvious. I just changed the rear rotors/pads, so I look to see if one came loose--but can't find anything. Turn the engine on with no problem and start to drive off. Now the grinding sounds gets a little worse, so I pull right back into the garage.
I'm afraid to ask, but, is my transmission shot? What is engaged when in neutral with the engine off?
Before I even had this problem I had made an appt. to have the transmission fluid and diff. lubricant changed. Now I'm wondering if I need a whole lot more.
Any help would be appreciated.
Folks,
