Expedition cuts all electrical, will not start. Help!
bosozoku
Idaho
Hello all.
So this morning I hop in my garaged 1998 Ford Expedition 4x4 4.6l 155k miles, turn it over and it starts up normally, but sounds a little 'off', so I shut it off and go to restart it and 'click', all power goes out (lights, locks, everything, it's like the battery is disconnected). I break out the multimeter and the battery check out fine, so I go to the big fuse block and power is on both sides.
I go inside the house and back out to the garage about 10 minutes later and the lights are on and everything looks normal again. I go to turn it over and 'click' all power goes out again. I wait for a few minutes, the lights click back on and I hook my code reader up and there are no codes, there appears to be full power, so I try to turn it over again, and 'click' the power is out again.
The 'anti-theft' light isn't on and I cannot figure out what is going on.
Any help would be appreciated!
Thank you.
Racenut
Deming, New Mexico
Clean your battery terminal conections and then also check the conections down at the starter. It sounds like either a coroded conection or a loose one.
bosozoku
bosozoku
Idaho
Alright, I admit I was a bit sleepy this morning and freaking out. After posting my message, I went back out and found a loose ground wire. Problem solved and off to work I went. Thanks for the advice, you were right on anyway.
