Expedition Problems
twkellen
KY
I have a 2007 Expedition. In August of 2011 I was going home and rounded a curve. The Expy just acted like someone turned the gas off. It started right back and I made it about another 500 feet and it quit for good. I towed it home and found out the fuel pump was fried. When I got it out, it showed it had gotten really hot. I replaced it and all was good until the week before Christmas. I was driving down the road at 60 mph and it was like someone turned the gas off. I had it towed home and replaced the pump again. This time it didn't look bad, but it was. This time I found a bunch of grit in the bottom of the tank. I cleaned it completely out and installed with the new pump. Back on the road and it was all good. Today I was headed home and the same thing again. Every time I could crank it forever and it wouldn't even hit. Same today. This time I had it towed home again and went out to jack it up to remove the tank. I thought to try it one more time, because it wasn't exactly where I wanted it. It fired right up. I scanned it and it has no codes. Now what? Anyone have any ideas? Every time I used a pump from my dealer, so I wouldn't think it is poor quality pumps. It was especially hot today, but the gauges never got out of the normal they always are on a cold day.
Thanks in advance for any help,
Wayne
911jason
Simi Valley, CA
I am absolutely NOT a mechanic, but the grit in the tank makes me wonder about the quality of the gas you've been using. Not sure if that long-term could be ruining your pumps.
Stoned06
Milwaukee
That, or someone is putting something in your tank. Have you checked the voltage at the pump to make sure its correct. If high, it could be burning out the pumps.
T
twkellen
KY
Ok, I was thinking the grit was the problem too. I was thinking more like a cracked tank or a hose not connected allowing road grit to get into it. I do drive on gravel some. However I removed the tank and pump today even though it was running. There was no grit in the tank. It was unbelievably clean.
I actually used the fuel pump hooked to cables and a battery to pump all the remaining fuel out of it. It pumped out 15 gallon with no problems and pretty quickly. Could the pump be working but getting hot and dropping pressure where it wont run?
I am thinking the pumps aren't the culprit now and it is possibly something that controls them. Any ideas? If it is voltage, what is controlling the voltage to the pump? I know there is a relay in a box under the hood. Will this kick out and then reset itself?
I am totally lost on this now since it restarted and seems to run fine.
Stoned06 - That picture looks identical to mine minus the boat. And minus the fuel tank and pump at the moment.
JUST4FUN
Admin
Moderator Administrator
Il
did you change the filter?
T
twkellen
KY
I haven't put it back together yet, but every time I have changed a pump so far I have changed the fuel filter too.
vegasdrummer
Henderson
I need a Fuel Pump for 2007
Ford has national shortage or recall. My pump is out now om my 2007 EL and I cant find one and Ford won't have one available until Sept 2013...
Anyone have one?
mrford60
SE pennsylvania
replace the relay when you put the new pump in this time. the relays can kick out and reset it ma have overloaded when you burnt the first pump and it is weak. good luck.
01yellerCobra
San Diego
You might want to check out the FPDM too. I believe it's on the rear frame rail. Some guys have had issues with them corroding and falling apart.
Misspelling brought to you by Tapatalk
CJ0920
Gainesville, VA
Any updates on your issue? How many miles on your truck?
How often are we supposed to be changing fuel filters? Don't mean to get off point, but cause to post some pics of an install?
