digitalH2O
Not sure where to post this because I don't know if it's electrical, drivetrain, or what. So, I'll post it here and hopefully it'll be moved to the appropriate forum. I assume it's a fuel system or drivetrain issue, but who knows. I'm certainly no expert.
The vehicle: completely stock 2005 Expedition XLT, 5.4 V8 w/83000 miles.
The problem: If I sit at about 1500 RMP, usually while doing between 50 and 55 MPH, the truck starts to buck very gently as if it's not getting enough fuel or something. The "Check Engine" light comes on when this happens.
If I'm heading uphill when this happens, the "Check Engine" light comes on and starts to blink.
I can usually fix this problem short-term using cruise control. However, it doesn't last long, only until the next time.
I can usually avoid this problem by powering through 55 MPH or cruising slower than that. The bucking can sometimes be felt briefly, but the light only comes on if I stay at that speed/rmp.
Any ideas what may be causing this? Any suggestions? Thanks!
