Extremely poor shifting
birdman45331
ohio
My 97 Expedition will not shift into gears properly. You go to take off and it will run up to 4500 or more rpms before it will shift. If you take off slowly and ease on fuel it will shift sooner. Then it gets up to shifting into overdrive and sometimes wont. I have had the tranny rebuilt and the abs speed sensor replaced. It also has new exhaust manifolds and plugs and wires.
Can anyone please help!!! I have a vss to put on, but have no idea where it goes. Really like vehicle, but will have to get rid of if I cant get it running right.
Someone please help.
jayhawk2014
Lawrence, KS
I read on the F150 Forum that a bad VSS can cause rough/erratic shifting, and that it should be located on the rear diff. somewhere.
joezek
psl, FL
sounds like a bad sensor somewhere. Maybe a throttle position sensor? If the computer thinks that you have your foot to the floor it will probably hold the gears to redline before shifting.
trdragons44
nj
the vss is located on the tailshaft housing on the rear of the transfer case. here is a pic
