F150 5100 Shocks F/2-inch of Lift Excactly?
Expedition Dave
A Tiny Little Dot in Florida
Any of y'all adjust your Bilstein 5100 F150 front shocks to produce ONLY 2 inches of lift, as opposed to (from what I have garnered here) the full 3 inches?
Also, is there any valving wonkiness with a 5100 series F150 shock up front, and a 5100 Expedition shock in the rear?
Shaffer9
Ms
If you use the f150 4wd fronts the bottom ring will give you ~3" from what people have reported. You can not go lower with them. I haven't seen anyone on here use the f150 2wd fronts and report results.
Shaffer9
Ms
The f150 2wd length is in between the expedition shocks and the 4wd. But Noone has shown what results moving up one setting above the lowest would yield.
sanman28
SW MO
These things are low riders. 3” is barely enough to look 4x4
