Finally did the timing chain on my truck!
max78
AZ
Rattle at start up and noise in general forced me to do the timing chain.
The passenger side chain had no tension, but the seal was just fine which I found odd. It was leaking somewhere but not at the seal. Driver side was blown but held tension. There was a little damage to the back of the crank wheel from the chain.
I did the Melling timing set 3-391SCC with the cast iron ratcheting tensioners and Melling M360HV.
The Melling tensioners are very nice pieces, and have a little port that sprays oil right on the chain which I thought was a nice touch. The Ford chain and sprocket look and feel MUCH nicer than the Melling stuff though.
Not a hard job, just time consuming.
Tools that made the job way easier.
Air hammer, put a wrench you don't care for on the fan clutch and hit it with the air hammer.
1/4" air ratchet.
Mountain RM6 ratcheting wrenches.
Nice powerful Impact drive for that crank bolt!
Irwin vice grips to rotate the cams because I'm cheap. No special cam tools needed!
Mistakes I made were. . .
I didn't have the valve cover gaskets. (I clearly wasn't thinking).
I needed a small 3 jaw puller to remove the balancer. (I had the screw type)
Removed the PS pump pulley, but didn't have the correct installer. . .
Working on the truck outside in the desert with LOTS of wind. . . .
Here are some pics!
TXFRDOwner
What did that cost You in parts ?
M
max78
AZ
About $550 for all parts including oil for an oil change after it was all done.
