Flasher
Bedrck47
Elizebethtown, PA
Attached are the prints doe the 09 expy the circuit for your 08 is the same and also for the 07 model year
look on print 90-03 it shows the circuit located in the fuse box print 90-02 shows the multi-function switch
  • 90-02.pdf
  • 90-03.pdf
Bedrck47
Elizebethtown, PA
Principles of Operation
NOTE: The Smart Junction Box (SJB) is also known as the Generic Electronic Module (GEM).
The SJB monitors the multifunction switch position by sending multiple voltage reference signals to the multifunction switch. When the multifunction switch is in the LH or RH TURN positions, or the hazard lamp switch is pressed, that input signal is routed to ground.
When the SJB receives a request for a turn signal or hazard lamps, the SJB supplies voltage to the appropriate turn lamps.
The timed on/off cycle is determined by the SJB and is set to flash approximately 80 times per minute if both the front and rear turn lamps operate correctly. If an individual turn signal lamp is inoperative, the SJB flashes the remaining turn lamp approximately 160 times per minute.
53bird
53bird
washinton state
Man! ask a question and get a precise answer Thanks so much for your time Bedrck I think you've solved my problem
