fog light mod
Fat Jack
Bella Vista arkansas
some where on here i saw a fog light mod tha a person could remove the ramp on the switch and have fogs at ant position on the switch? Any one got that link?
Thermo
technical advisor
I do not have the link, but i have done the mod and it is really easy. If you have any questions, let me know. The big thing is to wrap the headlight switch inside of a towel as you are pulling it apart. There is a spring inside that will go flying that is hard to find later.
Fat Jack
Fat Jack
GOTCHA! towell good, flyin spring bad!
thanks for your help
tsgrpr97
PA
Is there any way to get the fog lights to come on with the auto lights?
JTKustoms
Boston
Thermo I need some help, I tried this yet it still will not work. I used a dremel and took down the ramp so he knob does pull out perfectly without being turned fully to the headlight position, yet the fogs will still not come on without the low beams
Thermo
technical advisor
JTKustoms, you need to add a jumper wire between the brown and white/black wire. The brown wire is for the parking lights, the white/black wire is for the fog light relay actuation. So, no need to worry about overloading the headlight switch. Add that and then see what you have. The one "caution" that I will tell you about though is that doing this mod will also keep your fog lights on when you hit the high beams. In some states, this violates the law. Just a fair warning. Granted, if a cop sees you with your high beams on and your fog lights, odds are you are not in the best of conditions anyways.
JTKustoms
Boston
Works perfect, thanks a ton thermo. And about the high beams...I have hids so the high beams don't work anyways
whitelightning99
Pa
just wish i could use only the fog lights instead of having to have headlights on too.Any way to do that maybe it was said but i didnt read word for word ever comment
Yudaman
Southern Oregon
That didn't work well on my '98. It worked, but with high beams, both headlight beams came on together. Lots of light, but bulbs don't last long. I ended up wiring an external relay and it works perfect!
But '98's function a little different than '99-'02...
sharprd65
