Fog lights
dariod
Windy City
My fog lights stopped working. Before when I pulled switch it would show little lights on switch that fogs are on and now that light is not coming on. Is there a fuse for fogs? If so where is it located on 2011 Expedition thanks
D
dariod
Windy City
Ok found a problem it was fuse. But as soon as I put new fuse in it got also blown right away. What is to look at. Why is fuse getting blown all of a sudden after no problem for two years.
1997SCEBFEX
Northwest Panhandle
is there anything else on that circuit?
did you check the bulb holders to ensure that they're not rusted/occluded up, or you have a frayed wire touching metal?
Suspect you have a ground somewhere causing the fuse to blow.
PanHandler.
D
dariod
Windy City
Thanks for your reply. I will check more deeply but it is freaking cold in Chicago now so will have to wait for warmer day to work outside
metaldrgn
somewhere
Remove the bulbs and replace the fuse. If it burns out again you have a short to ground and you'll have to find out where it is.
