Follow-up to Leaking Sunroof!
jeff kushner
North of Annapolis
Thanks to the help of my friend Rwing21, I found the drains and cleared them as best I could but still had a little wetness issue. Then, I recalled a trick I use on old crankcase seals in my two stroke triples....I fill the cranks with Whites-Hydraulic stop-leak, let soak for a week or so then remove.... which causes the seals to swell to near new dimensions and stay that way for at least 2 or more years.
I went to my basement, got my gallon jug and repeatedly painted the sunroof seal all around.....did it a half dozen times in the morning and afternoon last week. Last night it poured....dry as a bone!!
Doesn't hurt paint either....the company "Whites" has been purchased by Blue Devil but the product is identical. I know because I called the factory in Baltimore and checked.
Amazon.com: White Shpherd Hydraulic Stop Leak (1 gallon): Automotive
Jeff
rwing21
Louisville
Jeff
Good to hear. Much cheaper than the route I went. It was $107 for the new sun roof seal from Ford.
Glad to hear you got it!
