Ford Factory Tint
LazSlate
Arizona
Just picked up my 2022 Timberline and was wondering what the factory tint is. Looks like the front has none but the backs seem kinda dark maybe 20%? I want to make the backs darker. Has anyone had their Gen 4 tinted all around and what % did you use. Thanks!
HtownHog
Houston
Privacy glass is around 25% but is just a darkening function, nothing else. I’m in Texas and plan to go to legal minimum on the fronts (35%) and have the same done to all the back windows but it will be done on top of the factory privacy coating. Biggest thing will be the ceramic tint finish for UV protection. Also getting an 80% windshield covering, not sure yet on the sunroof but probably the same for that too.
USKflt
Colorado
I did ceramic on everything but the windshield. Fronts are 35, sunroof is 70 and all the factory darkened windows are the clear tint.
LazSlate
LazSlate
Arizona
What does 35% applied to the rears (with factory tinted glass) look like? Is it too dark or perfect?
The VLT calculator say a 20% factory with 35% film is a vlt of 7%.
I held up a piece of 35% to my rears and it did not seem that much darker. Albeit the tine was not installed just holding up.
HtownHog
Houston
The GM privacy glass is very similar from what I can tell to Ford. Here is an Escalade that did 35% all around, you can see the front driver's window is not as dark as the rear door and back window. Best part with the ceramic tint is inside looking out is quite clear and bright actually. Had my wife's windshield on her car done and it is significantly cooler in our Texas heat than my car that didn't get the windshield covered.
Lou Hamilton
Maryland
A place that I talked to about getting mine done said that 35% on the front doors and 50% on the rear gives it a very even look all around for the Fords.
LG_123
Toronto
I tinted the windows all the way around including both windshields. I put 90% on the front which looks clear but helps with heat reduction. It makes a massive difference and nano ceramic tint is a MUST. There’s no point in using carbon tint.
35% on the front (to keep the cops happy), 25% on the rears (which looks like blackout because of the existing tint; I can’t see through my windows with my nose pressed against them).
APExpo
Kentucky
This is 50 on the windshield, 20 on the driver/passenger, and 50 on top of the rear privacy glass.
HtownHog
Houston
Where do you live that you can get away with those options? Texas any more than 80-90% on the windshield and you can get pulled over quick. Law says 35% on the front side windows but people get away with a little darker depending on your skin tone and parts of Houston you are cruising through.
Can you take some pictures from inside to out for each window? I was really considering 35% all around but might be too dark for the rear windows.
LazSlate
LazSlate
Arizona
Just tinted mine with Ceramic 30%. I could not find 35% pre cut ceramic so I went with 30%. My state has a 33% rule so I figured 30% would work with the error factor. Otherwise I would have to go with non ceramic or 40%. I also tinted the rears with 30% and its kind of limo from the outside but looks good and from the inside really not much difference. Seems a tad darker but not much. You would think factory 20 and a layer of 30% would be super dark but its not.
Jchamp
Tn
I did 20 percent all the way around on all windows and 35 full windshield. Best decision ever.
Jmschultz22
Detroit, Michigan
Just had mine tinted at 20% to match factory tint, just for reference. 6484B2CE-414C-40EC-8C07-9C32603EF341.jpeg
APExpo
Kentucky
APExpo
Kentucky
I guess KY’s pretty lax on enforcement. The fronts are illegal, but I think we have a “multi-purpose vehicle” loophole for trucks/vans/SUVs that lets you go all the way to 8% in the back.
As long as there is some light you can see out of everything no problem. But if it’s pitch black with no street lights or other car headlights, the sides are kinda tough.
ManUpOrShutUp
PA
15-20% on the fronts would be the appropriate tint to match the rears. I have Llumar FormulaOne Pinnacle 15 (19% light transmission) on my front side windows.
Jamaican Cruiser
Vienna, VA
I think you need to read very carefully. I also lived in Texas and has the windows tinted legally, but they looked darker than expected. I had a black interior which really helped. You can have very dark tint on the visor strip (NOT the entire windshield) as long as you stay above the AS1 line. You can also tint everything behind the driver seat very dark, except for the rear window. remember this is on top of the factory tint
HtownHog
Houston
my favorite part of the texas tint laws is actually the rear window regulations, tl:dr you can completely black out the back glass and side windows behind the front seats if you have two outside side mirrors. Also didn't realize they changed it to 25%, not sure when that occurred as I remember it being 35% not too long ago:
Rear Window
A sunscreening device can be applied to the rear window of the vehicle if the following conditions are met.
  1. If a motor vehicle is equipped with an outside mirror on each side of the vehicle that reflects to the vehicle operator a view of the roadway for a distance of at least 200 feet from the rear of the vehicle then there are no restrictions regarding the sunscreening devices applied to the rear window.
If a motor vehicle is not equipped with such mirrors then the rear window must meet the following standards:
  1. Sunscreening devices, when measured in combination with the original glass, must have a light transmittance value of 25% or more.
  2. Sunscreening devices, when measured in combination with the original glass, must have a luminous reflectance value of 25% or less.
Fastcar
Army
FL
Getting a ticket for window tint from a cop whose car has privacy tint all around is BS!
ManUpOrShutUp
PA
Many officers also run red lights, speed, etc. with lights/sirens off. When I was in college, my boss at the pizza shop used to sell stolen goods to the patrol officers. After his shop closed down, I went to another and the owner of that place actually had the Sheriff's deputies come and sell him weed that they had confiscated from people they pulled over. It's all BS, but that's the world. :p
