FORscan question
Snilved
North Dakota
Have a 2020 Expedition Limited. Made one change via FORscan to stop double horn beep using the easy mode. The double beep stopped, but so did door chimes and seatbelt warning.
Could one change in the friendly mode affect other settings..??
LokiWolf
Moderator
Richmond VA
First things first. There is a FORSCAN area to this Forum. I suggest you post this question there.
The simple answer is no. Those settings should not be affected by each other. Mine were not.
What did you do after you made the changes. Turn car off?
Have you put the setting back, and did they return?
S
Snilved
North Dakota
Sorry, newbie... Will try posting on FORscan forum, although I didn't find a way to do so when I dropped in on that forum.
Yes, turned car off after writing. Haven't tried to turn double beep back on yet, but will do so.
chrismomo5969
