Fosgate Issue
TexasAngel34
Peyton, CO
One of my 15's decided it wanted to stop working... there are no signs of punctures , the cone itself wont move or nothing... Anyone have any ideas? is this fixable or no..
Newport News, VA
Troubleshoot...switch subs...if still nothing check connections...if other sub plays after swap its sub...something could've came loose...speaker wire...rca...check wires on sub and make sure they didn't come off too...if all is good and sub still doesn't play if you bought from dealer it should be straight swap from dealer unless really old...spider...coil...terminal...can be fixed unless motor went... still can be fixed
TexasAngel34
TexasAngel34
Peyton, CO
checked all that nothing works but the other one works... roommate says the coils inside are frooze up .. gonna call a audio place and take it to them tomorrow and see... bought them last year at a clearance sale so im gonna have to buy a new one...
Newport News, VA
Froze up? Take it inside if its that cold there...
oblivion
Ontario Canada
If its actually frozen you have bigger problems in there. If you bring it inside for a while and it loosens up, play that thing HARD for a while to get the voice coil good and hot. Then bring it back inside to cool. You will have burned off the condensation but if left out in the cold it will return.
If it doesnt losen, time for a new sub.
AcesOverEights
MN
I think he meant froze up as in the voice coils have seized.
Ive done it to a couple subs. If thats what happened its pretty much just a huge paperweight. is it still under warranty? They might fix it(or replace) if so.
TexasAngel34
TexasAngel34
Peyton, CO
just gonna replace it to be on the safe side... thanks for all the info and help...
