Front Wheel Bearings / Hub Assy
eurolux
Raleigh, NC
Hi,
1999 EB 2WD. My front wheel bearings are shot. I need to either replace the bearings or the hub assembly. When I search for a hub assembly on Amazon etc. the only option I see is for 4WD. I do not see an option for 2WD. My guess is the same hub assembly is used for both the 2WD and 4WD, just the splines are not used for 2WD. Do any of you know if this is correct??
TIA for your help
Expd830
Chicago
All I can find is 4WD, so I looked under AutoZone and this is what I found so I would go there to see if they have the part number for the whole assembly.
Autozone: Duralast Bearing Set 11
$11.99
Calabrio
Sarasota, FL
And always be careful with Amazon parts, be very careful of the vendor.
Everything isn't sold by Amazon directly. And many of those auto part vendors sell counterfeited and rejected parts. I bought a set of "Motorcraft" ignition coils that all failed within 20k miles. One within just two weeks.
