Psychobot90
In my experience with these engines, one bad sensor could throw multiple codes for anything downstream. In the case of the ecoboost specifically, it could throw codes for upstream sensors as well since it's a closed system. Is there any way to verify a bad purge valve? Any way to test the existing part? Your codes could point to any one of several intake/exhaust related sensors. I guess back to my previous question; were you able to squeeze any of the reasoning out of Ford for this diagnosis? Did they provide any other possible culprits? What's your backup approach if the parts swap doesn't clear the codes?That’s what hacked me off about the dealer—they said the purge was bad, but there could be other problems too. I had already tested the purge and thought it was good. I questioned the diagnostic and they said anything additional was additional whether the purge valve fixed it or not. I decided to do my own parts changing if that is how they operate. With 21K miles, how likely is it there are multiple failures in the system occurring simultaneously? Nil in my opinion, but if there is something else, the PCV is just as easily accessed and replaced if needed. But if it is not the purge valve, I think fuel pressure would be the next suspect—injection pressure sensor.
Sent from my SM-G998U using Tapatalk
