Fuel Pump Malfunction
Swmpbgy1
WV
Greetings all.........
I managed to replace my fuel and air filters as suggested by my local Ford service rep to eliminate a slight hesitation I was having under slight load at highway speeds.
Drove it for the first time over Thanksgiving.....1300 miles round trip. The first 300 miles were through heavy rain from winter storm boreass. The Expy stumbled and bucked if I had to pull up a hard grade, so I feathered the gas pedal to avoid the hesitation/bucking. The next several day were dry and we arrived home without so much as a hickup.
Let me get into the fuel filter change......it went well. The only issue I had were the 4 plastic clips on the 2 outboard lines. The black and white clips broke......the blue one was missing and the red one came out in pieces. I was able to replace the white and black ones....Advance had those in stock. The red and blue ones were not replaced. Called the dealership and they told me I woujld have to replace the lines to get the blue and red clips....DOH!! Long story short....service manager said that without the red and blue clips the fuel lines would suck air and water if not in place. Is this possible??
When we got back I ran the Expy over to Advance to read the codes.....NO CEL ever came on during the trip, but there was an error message that the fuel pump had a malfunction. I explained the above to the Advance guy, who is a experienced Ford 5.4l owner, and thoght I needed those clips that I was missing.
The 2 fuel lines will run about $300......My thought was to cut the 2 ends off and replace with barbed fittings, some fuel line and band clamps. Do you think this would work? have any of you done this? It would make the next filter change much easier.
Let me know what yall think..........
Swmpbgy
RI-Matt
Rhode Island
The symptoms you posted sounded more like a coil going out then the air or fuel filter being clogged. When I had a coil going out on my 06 F150 it would buck and hesitate like cazy on the highway under load. I would think the heavy rain would just magnify the issue. Moisture and water are not good for the coils.
Matt
metaldrgn
somewhere
mrford60
SE pennsylvania
what year is your expy, I have a parts expy and may have your clips you need. pm me if you can and I will look to see if I have them.
S
Swmpbgy1
WV
Thanks for all of the replies......The ford dealership I think was just trying to save me some $$ by having me replace the filters first.....The truck only has 43,000 miles on it and I am the second owner......not sure when the last filter change was.
I think my next step will be to replace the plugs....Where can one buy the plug puller in case I break one....Advance has them for $100....I'd rather rent one, but I don't think its possible. The less expensive the better.
Swmpbgy
