Grinding when ... stopped?
Franklin Jones
Nebraska
Ok fellas, this is a new one for me.
I get a grinding noise when I turn the wheel all the way to the left when near the end of the steering wheel travel. It happens and is most apparent at low speeds, which is fairly common and could point toward a cv joint or bearing, right? Even an IWE, but I replaced those this year already....
But it also does it when I’m at a full stop.
Which, to be honest, is kinda great because I can easily recreate the noise! But I’m not aware of any suspension component that makes noise when you’re stopped.
Any ideas?
Yupster Dog
Super Moderator
Super Moderator
If you can make it grind at full stop then it should be pretty easy to find. Put up on jack stands and find the grind.
r98exp1
