Groaning noise front rear suspension
Funugy
Frisco TX
Have a groaning noise when going over bumps. Are there any lubrication point in the rear end ....grease zirts perhaps? If not, would it be advisable to spray wd40 on the suspension areas or would this do more harm than good?
sbar09
michigan
pinon bearings or rear differential. You can try adding friction modifier to your diff and see if that helps
F
Funugy
Frisco TX
No, I don't think that's it. When the vehicle is stationary, you can bounce the fender and it makes the noise. It's definitely coming from the suspension. Any ideas on how to fix?
sbar09
michigan
Shock bushings or MAAAYbe stabilizer links. Just start searching for worn or missing bushings or other rubber pieces haha
Hamfisted
Ft Lauderdale
Have you looked under the truck ? What year is it? More than ten years old any of the rubber parts will start to show their age. My first guess would be swaybar end links, then ball joints. But it could be any rubber under there. Lay under the truck and have someone bounce it up and down so you can see where it's coming from.
-Mike
F
Funugy
Frisco TX
-Mike
It's an '03. Good idea on your suggestion. I'll have my wife bounce up and down as I lay underneath. Wouldn't be the first time :)
f162mm
Also keep in mind that WD-40 will be very temporary fix if the bushing cannot be lubed. The long term fix is to have bushings replaced which is not as hard as you might think.
