I do have a plethora of dealers here in the Nashville area they’re just all 30 minutes away and my dealer is 10.
I will say my service advisor is very friendly, always makes sure I’m happy/taken care of it’s just their actual mechanics that seem to be sloppy.
like I said, I just think I need to be adamant about what the issue is and really be more involved in the repair process. I don’t like picking up the car to find out they “cleaned the area around the lane keep camera” and claim it’s fixed. I did that, it didn’t work.
Being more involved / maybe even getting the mechanics out to talk with me going forward will be needed.
Good luck.
I have found that service advisors are often very resistive of allowing the customer to speak to the technician.
In 2020, I took my Expedition to the dealer for a problem with the coolant leaking. The first time, the system was pressurized and no leaks found. When I got the vehicle back, it continued to loose coolant over 1-2 weeks. I returned it, and then the technician found a defective coolant reservoir and several hoses that were leaking - all replaced (after I insisted there was a leak and I wanted it found).
Later, the vehicle continued to loose coolant (from the reservoir), and I took it back for a second round of visits. The first time, a pressure check revealed no leaks. When I got the vehicle back, it continued to loose coolant from the reservoir. I returned the vehicle to the dealer, and this time the technician found a leaking water pump when he put the vehicle on a lift. It was replaced, as well as another hose.
Each visit, I asked the service advisor if the technician put the vehicle on a lift, and checked for leaks under the vehicle. I was told that the way leaks are found, is to pressurize the system to see if the pressure drops - indicating a leak. Each time, I told the service advisor that there had to be a leak, and if a pressure test did not find it - the vehicle underside should be examined (as the coolant had to go somewhere and may only leak when the engine is warmed-up). They were resistive of my advice. I have undergone four major surgeries and no longer can do many vehicle maintenance tasks - including getting under my vehicles.
Service advisors are nothing more than salesman, who “write up” the vehicle and turn it over to a technician with very little description of the problem. I wish I had a dime for every service advisor that told me I was due for (fill in the blank for an expensive maintenance item that was not due by mileage or time).
Good luck again.
