Harsh engagement from park/reverse/neutral to drive.
A
affordable
little rock
Just used different valve bodies some from remanufacturers and some from the dealer would work. Seems to work the best when you put the strategy, clear adaptive tables, and clear the PCM tables. When you do a drive after you clear everything, light throttle until 10th gear and slowly break. Put it on neutral for a few seconds, reverse for a few seconds, then repeat about 5 times. This fixed the issue mostly but still have this issue sometimes.
ahammed akkif
saudi Arabia
Has anyone found a solution to this problem? I have this problem too. I understand it is a software issue. Can I update it using forscan?
