Have an 08 with lots of wind noise
dave91gt
wv
I assume the wifes expy has had 1 door mirror replaced by the original owner. The drivers side door has a loud wind noise especially now that it is colder. I did find that Ford had a tsb back then for wind noise related to the door mirrors. The drivers door mirror plastic is textured and the passenger door is smooth. Does anyone know which one is original and if this is an indicator the tsb was done on one of the doors?
01yellerCobra
San Diego
Both mirrors on my 08 are textured. I don't know if the TSB has been done. I didn't know there was a TSB to be honest.
Misspelling brought to you by Tapatalk
911jason
Simi Valley, CA
I've had bad wind noise on my 2007 EL from the beginning. There was a mod on here where someone had inserted surgical tubing into their door seals and it supposedly helped quite a bit. I never got around to trying it.
RI-Matt
Rhode Island
If you have an Eddie Bauer then the textured one is the original one. Only the Limiteds came with smooth finished ( color matched )
Don't know if this TSB would apply as it was for 2007 MY
TSB
07-16-15 •WIND NOISE - A PILLAR AREA - BUILT BEFORE 5/7/2007
Publication Date: August 7, 2007
FORD: 2007 Expedition
LINCOLN: 2007 Navigator
ISSUE:
Some 2007 Expedition and Navigator vehicles built before 05/07/2007 may exhibit wind noise around the exterior driver and/or passenger doors. This may be most noticeable near the A-pillar area of the door.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE: IF THE VEHICLE BUILD DATE IS ON OR AFTER 5/07/2007, THIS TSB DOES NOT APPLY. CONTINUE WITH NORMAL WORKSHOP MANUAL DIAGNOSTICS.
1.Tape the trailing edge of the mirror sail down to the front window glass from the tip of the mirror sail to the belt molding.
2.If the noise goes away, replace the mirror on the effected side. Both mirrors do not have to be replaced.
3.If the noise does not go away, continue with normal Workshop Manual (WSM), Section 100-04 diagnostics.
PART NUMBER PART NAME
8L1Z-17682-AA Mirror - Expedition-Passenger - Power/Heated Convex - Middle Eastern Countries
8L1Z-17682-BA Mirror - Expedition-Passenger - Power Heat/Memory
8L1Z-17682-CA Mirror - Expedition-Passenger - Power Heat/Memory - Middle Eastern Countries
8L1Z-17682-DA Mirror - Expedition-Passenger - Power/Heated Convex
7L1Z-17682-EA Mirror - Expedition-Passenger - Power
7L1Z-17682-FA Mirror - Expedition-Passenger - Power - Middle Eastern Countries
8L1Z-17682-GA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold / Expedition-Power Fold, Power Adjust
8L1Z-17682-HA Mirror - Expedition-Passenger - Power Fold/Power Adjust - Middle Eastern Countries
8L7Z-17682-AA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold
8L7Z-17682-BA Mirror - Navigator-Passenger - Power Heat/Memory Power Fold - Middle Eastern Countries
8L1Z-17683-AA Mirror - Expedition-Driver - Power/Heated
8L1Z-17683-BA Mirror - Expedition-Driver - Power/Memory/Heat
7L1Z-17683-CA Mirror - Expedition-Passenger - Power Heat/Memory - Middle Eastern Countries
8L1Z-17683-DA Mirror - Navigator-Drivers - Power Heat/Memory/Power Fold / Expedition-Power Fold/Power Adjust
8L7Z-17683-AA Mirror - Navigator-Drivers - Side Power Heat/Memory/Power Fold
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
071615A 2007 Expedition/Navigator: Replace One Mirror, Includes Time To Road Test To Verify Concern (Do Not Use With 17682C, 23943A) 0.7 Hr.
071615B 2007 Expedition/Navigator: Replace Both Mirrors, Includes Time To Road Test To Verify Concern (Do Not Use With 17682C, 23943A) 1.1 Hrs.
071615C 2007 Expedition/Navigator: Extra Time To Paint One Mirror, This Labor Operation Should Be Claimed With Labor Operation A (Do Not Use With P101, P17) 1.0 Hr.
071615D 2007 Expedition/Navigator: Extra Time To Paint Both Mirror, This Labor Operation Should Be Claimed With Labor Operation B (Do Not Use With P101, P17) 1.5 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
17682 07
Matt
D
dave91gt
wv
Thanks. I do have an EB. Both mirrors are natural plastic (black)- just one is textured and the other is smooth. It "sounds" like the wind noise is coming up the weatherstripping between the body and door. I can push in on it at highway speeds and it slightly changes it.
frankie paladin
NY
I have a 2007 Limited, I had terrible wind noise when the car was new. Ford installed new weather stripping and it worked for about 6 months, then the noise came back.
