Mediamonkey11
My parents have an identical '00 EB with the 5.4, they took it to a mechanic due to it throwing a head temp code and using about a gallon of coolant a week. They tested for combustion gasses and came up positive.
My question is, is it worthit to fix as I called another mechanic I trust and they remove the motor completely and for both heads to get done (new gaskets, resurfacing, reinstallation) with parts and labor would be about 25-2900 depending on what all machine shop work needs done (2000 labor). The other option they are considering is to get a whole new engine for $2500 and have the shop put it in for the same labor essentially.
They want to know if the truck is worth putting that money into (all else is in good shape, I changed the trans fluid and it didn't need it really... I did the filter and flushed the fluid), and which way they should go if they do. My mom loves the fact the truck is so comfortable but hates the mileage.
The mechanic they took it to said that the 5.4 is a POS, which is why I pointed them in the direction of my mechanic. I have told them otherwise, am I wrong? I thought these were pretty stout motors!
