Hearing gas slosh around
Denethor
Durham, NC
are you sure its gas and not a leak in the rear and fender well filling with water? mud or some other object may have clogged the drain hole.
Adieu
SoCal
Is it an odd bubbling sound on startup?"
I think thats coolant or oil
B
Butch Smith
Atlanta,Georgia
Sounds like a large container of fluid sloshing around coming from the back on the passengers side. Definitely not coolant or oil. I do not have a sun roof so no drainage holes to leak.
Denethor
Durham, NC
Doesn't have to come from sun roof, any window seal could be leaking or some other entry point.
Tap on the lower panels on each side, see if one sounds like its full of water.
ExpeditionAndy
Fort Wayne, Indiana
Check the rear passenger side door and make sure the drain holes are open. The lower part of the door could be full of water.
Denethor
Durham, NC
And just to point out, it's perfectly normal for some water to get in there, hence the drain holes. The water does not mean you have a problem with your window seals or something, just that debris had clogged the drain holes, very common and why I stated it early on. My friends Chrysler is the worst I've seen at collecting water.
