mschissler
Hi,
I have a 2000 Eddie Bauer Expedition with the 5.4L V8. When it is above 85 degrees outside I have a problem. When I start the car the engine is roaring and after a minute it will idle like normal. When I start driving and am in first gear I will get up to 3000rpm before it shifts. The engine sounds like a tornado. After a while and I get going it seems to calm down. Sometimes on a hot day after I make a few stops it will continue (High Revs) and I'll have very little power starting from a dead stop. When the temperature is below 85 I have no problems. I thought it was the transmission and took it to the dealer who ran a check and there are no codes, no problems. (right). Has anyone ever heard of a problem like this. Is this an Idle problem as it occurs as soon as I start the car? thanks for your help!
Marc
Marc
