High Idle
S
sphillips
Idaho
I would start simple, unhook the battery and clean the throttle body and maf sensors, reconnect the battery after one hour then go thru the idle relearn procedure:
1.) start it in park with all accessories off
2.) idle till you reach operating temp
3.) turn ac on max, idle for one minute
4.) put in d while still running and ac on, let it idle for one minute
5.) go for a short drive see if that changes your idle
Went thru these procedures, idles at 950, so slightly better
Glad you got your idle down. What brand did you buy that worked? It will help other members.
S
sphillips
Idaho
Sorry about late response. IAC is from Rock Auto, made by Hitachi. BUT, nothing lasts forever, idle is back to 950-GRRRR!
Check one of the prior posts from one of our members.Doc Raymond, He had posted a way to test them if bad.
S
sphillips
Idaho
Will do. Also, realized the car has adjustable pedals which were adjusted all the way towards the seat. Moved them towards the firewall and idle came down to 800. Coincidence?
S
sphillips
Idaho
Well, its fixed, but not sure why, someone will have to explain this to me. $4 part and 10min fix. I replaced the PCV valve and now it idles at 650, doesn't roar to 1700 on start, about 1300rpm and drops right on down.
aircargoo
new jersey
i u\just seen this and had exact problem. i was going to inform you check your hoses ect....pcv valve leaking is like having a leak with a loose air filter. trucks idle goes up.pvc hose goes straight into throttle bodys rear/back....glad you found problem...
expresspedition
