jeff kushner
Thanks Andy, I thought it had the larger Tranny cooler....thanks for confirming it!
jeff
jeff
again i say, there are very knowledgeable people on bitog. more than here. are all of them in that class? helz no...
First Mercon LV (recommend for 6R80 transmission) is a semi-synthetic. It is definitely good for HIGHER CONTINUOUS OPERATING TEMPERATURE than Mercon V. Any document that references them BOTH in the context of the same operating temperature is distributing bad information.who the eff said anything about all day?
learn to read.... i said the enemy isn't the oil, it's the sluff from clutch material contaminating the oil- and it should be replaced immediately. however, 240 isn't a big deal anymore for short periods of time and as long as it's allowed to circulate and cool before it stops pumping through.
This is a great piece if info since I got mine used. Thane for posting it.If you go to this site: https://www.etis.ford.com/vehicleRe...tpWQ0ivvUUXbtArGP9hg-VYVpZEx_uUET.eccvas1900m and put in your VIN it will give you the build sheet for your truck and tell you exactly what it has in it.
Mike you are welcome. I think there are other places online where you can just download the owner's manual by searching for 20XX Expedition Owner's Manual PDF and you can find it that way too.This is a great piece if info since I got mine used. Thane for posting it.
