Hit 150k and going downhill
AJ_KC
US
I just hit 150k on my 2010 Limited and, I'm sure it's a coincidence, I'm having a slew electrical issues.
Here's what I'm dealing with:
- Driver brake light and blinker out but running lights still working.
- Keypad lighting up but not responding to touch
- ABS, Brake, and Traction control lights irregularly coming on.
- Driver side running board not working and making a loud obnoxious clicking type noise.
- A/C making clicking sounds - was mainly doing it at lower temps but is becoming more frequent.
- At one point I lost the A/C completely but thankfully it started functioning.
I'm at a loss here and don't know where to begin. I should probably take it in for troubleshooting and repairs but the budget says I should attempt to DIY some of these issues before going that route. If anyone has any suggestions on a place to start, I would greatly appreciate it.
RhinoQuartz
USA/CAN
Any lights come on in the dash? Maybe a scan tool/forscan.
Check the wiring connections throughout your vehicle as well as the fuses.
Plati
how old is battery? is it good? good charging?
A
AJ_KC
US
The ABS, Brake, and Traction Control lights will all come on at the same time but they're inconsistent. Everytime I turn the truck off they reset everytime I shut the truck off.
That’s an indicator you have a bad wheel bearing somewhere. Mine did that on and off until I plugged in scanner and told me which hub assembly was bad.
A
AJ_KC
US
That's good to know. I'll have to see if I can get my hands on an ABS scanner.
RhinoQuartz
USA/CAN
You're looking for an OBD II scanner, ELM 27 that has MS-CAN and HS-CAN capabilities. Amazon or eBay is your best bet for them.
