Casflynn
Here are my numbers from todays weigh, 17 Expedition, 19 Mini Lite 2508, Hensley Hitch:
Truck Specs, 3550 Steer, 4300 Drive, 7500 GVW, 15200 GCW
Trailer Specs, 5980 GVW, 4464 Dry, 660 Hitch dry
1) Truck Only, 3120 Steer, 3180 Drive, 6300 Gross
2) Truck, Trailer, bars loose, 2580 Steer, 4620 Drive, 7200 GVW, 4000 Trailer, 11200 Combined. Wow did the front get light, rear axle is 320 over.
3) Hensley 1000lb bars jacked all the way, 3080 Steer, 3940 Drive, 7020 GVW, 4180 Trailer, 11200 Combo. Tongue weight calculates to 900 pounds (this included the entire Hensley set up, 2 full 30lb propane, battery and stuff in front storage, Hensley stinger was weighted with the truck, so my best guess is true tongue weight is 700).
** Fender measurements went like this,
Truck 35-1/2 F 34-5/8 R
Combo no bars, 36-1/2, 32-3/8
Combo with bars, 35-1/2, 33-1/2
Impressions: Under all weights for the truck, but close on rear axle by 360lbs. Front fender come back to same, but Ford wants a 50% return????, and the weight almost all returns sans 40lbs. Should I back off the jacks? Trailer looks level, still some sag from rear of truck at 1-1/8". Tongue weight % is almost 18%. Would going to a straight stinger as oppose to a 2" drop maybe lighten the load, but then I think the trailer would be slightly nose up? I also still haven't packed all the kids crap in the back bunks.
Took out on I-80 today in PA to get to the scale, seemed to tow fine, was running 65 getting passed by dump trucks and semis, no sway, not a lot of porpoise at all, little squirm from the P rated tires and independent rear. But all in all a good tow.
Any Feedback would be appreciated!!!!
Thanks!
Thanks!
