Hitch cover replacement
nationalgallery
Also, the aerosol touch up paint from scratcheshappen.com is a perfect match and flowed out really well. Cant tell it apart from the factory.
What color did you use? When I put in the model info it only shows the body colors, not that silver trim color.
Rick_cp
Grass Valley, California
Inspired by TravisD I followed suit with my version. If your ball mount tube is long enough it's no problem putting the pin and clip in the receiver with the hitch inserted through the modified cover. The flat 4 pin connector installed easily and is attached to the stock mounted one with a short extension.
NSRacer
AZ
That looks great!! Question - did you buy a pre-painted cover, or did you paint it yourself?
mrbiscuit
Western WA
What if you just get some split rubber edging to go around the opening in the bumper? Would probably cover up the ugliness from that pop-out piece pretty well, or at least inexpensively.
