How to listen to Bluetooth headphones while CarPlay plugged in?
jastevenson
AZ
Hi all,
Sometimes I want to listen to Bluetooth headphones but also have CarPlay plugged in (for Maps). For example, my kids might be in the back sleeping and I don’t want to wake them.
However, it seems like I can’t connect to my Bluetooth headphones because CarPlay overrides it.
Has anyone had success getting this to work? Not sure if it is a headphones issue and not a car/CarPlay issue.
Thanks!
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Hi all,
Thanks!
It is doable. Haven't tried in a while, but on my previous vehicle, a 16 Edge with Sync 3, I did it by accident once. You have to connect your Headphones after Carplay is attached I believe. Also be aware in many States it is illegal to use any headphones that cover both ears while driving.
aggiegrad05
North Texas
I do it all the time on road trips so I can listen to podcasts while the kids do other stuff. Granted, I use AirPods, so they may play a little better with CarPlay than others.
As @LokiWolf said, just wait until CarPlay is up and running then try to connect your headphones, should work
wakeboarder
Fort Lauderdale, FL
Hi all,
Thanks!
An potential alternative would be to adjust the balance and fade to the front left on the expedition.
