How to open rear hatch
Charly
Miami
Well the tittle ses it all the door lock actuator went out and i need to open but the key slot is broken (theft of rear seat) and i need to replace bulbs in tail light how can i get it open? Can it be oppen from the inside?
Sent from my SPH-L710 using Tapatalk
ydopen
Puckett, Ms
Take a screw driver and beat it into the key hole, put a pair of vice grips on it and break the lock. should be able to turn it with the screw driver then to loc or unlock it, then get a new rear lock
gaping46and2
Stoned06
Milwaukee
The only thing I would add to that video is DO NOT rip the vapor barrier like that guy did. Gently pull it from the hatch and it will re-apply when you are done. If you rip it like that, you will get water in your vehicle when it rains or you wash the car.
C
Charly
Miami
Thats a little too aggressive but that will be my last option
C
Charly
Miami
Mines is a 2002 but it shouldn't be too different il give it a try... you wouldn't happen to know if those are plastic hooks or they just pin into the door would you. Dont want to rip it apart and not get it back on
Stoned06
Milwaukee
Not sure on the 2002, but the inside trim on my '06 has metal clips that snap into the hatch. I would assume the '02 is the same, but not 100% sure. I was being careful when removing my trim, and I had a few clips break. Had to buy a package through Ford, and for what they are, it was a bit expensive. I think 4 clips cost $12.
C
Charly
Miami
Its the same in my 3rd gen but never done a 1st gen
ydopen
Puckett, Ms
LOL Tie a chain around the latch and hook it ti a truck bumper and floor it, It will open then:sparta:
C
Charly
Miami
Lol thats also another way to get it done
