How to remove base center console
Norexp
Norway
I own a 04 EB Expedition.
I need to remove the base center console. I have already removed the top part, and 2 screwes on the back sides and 2 at the front (under the heater/AC display).
I can`t really see how to remove the rest of the console. Does anyone have any tips?
Thanks in advance :)
Marthin
Norway
ELVATO
Orlando, FL
The whole center console? After you remove the top part (the one with the cupholders) I think there are a couple bolts that hold it down. This is assuming you removed the screws the rear of front seats.
At least that's what I remember from the manual. I'll post the actual instructions tomorrow after I hopefully get my CD drive working again.
N
Norexp
Norway
Thank you very much for your answer.
Yes, I want to remove the whole center console, and I have already removed the top part, and also the 2 screws at the rear of the front seats and 2 screws in front of the console.
I would be very grateful for the actual instructions.
ELVATO
Orlando, FL
After you've removed the top part, you should be able to see "into" the console.
1. Remove the bolt holding down the electrical connector.
2. Remove the connector.
Remove screws and bolts.
N
Norexp
Norway
Thank you so much for the informative answer. Will try this as soon as I`m back home from work.
Not many Expeditions in Norway, so hard to find any help home:)
N
Norexp
Norway
Very easy to remove:)
Thank you for all help
Marthin
Norway
