SOLISIMO
I though I'd post this for those looking to do this mod.
It's a ten minute job - you need a flat blade screwdriver and a #27 torx driver. Insert the screwdriver under the rearmost edge of the rear plastic caps on the rack (between the cap and the rubber base) and lift up. The cap will pop off. Repeat for all four caps (screwdriver under the front most edge on the front caps.) FYI. the cap faces outward.
Remove the two torx screws under each cap.
Slide the entire rack rearward to disengage the keyhole locks on the center mount.
Re-install the removed screws, with some rubber washers underneath (the nut-serts are through holes). If you are not going to mount another rack, consider more thorough sealing against water.
