i just bought a 2015 X have questions about suspension
Virgil miranda
New Bedford
i have 2015 x limited with 20" wheels it has 44k on it . this is my first expedition ive ha a few newer f150s my question is is our suspension anything fancy ive read different things on different years and models like ccd, load leveling , advancetrac rsc, etc not sure what i have but my truck feels like its all over place when i hit bumps not sure if thats how these ride cause im use to f150s or if theres issues with my suspension
bobmbx
Expeditions are large SUVs, and they are top-heavy compared to most other vehicle designs. That will give you the sensation that you're tipping over or wallowing as you drive around. Its unlikely, but not impossible, that your suspension is having an issue considering the mileage.
oldpaddy
Cape Cod
My '14 doesn't feel bouncy at all. Sounds like you've got something else going on.
Black
Kentucky
I just bought a 2016 with 46k. No way I would call it bouncy. Much smoother ride ride than the 2014 Sienna with 50k miles I got rid of.
Sounds like something is wrong.
V
Virgil miranda
New Bedford
does anyone know what kind of suspension system i have is there anything electrical with my suspension front or rear
Sccritterkiller
SC
Fronts are standard coil over...I would check the rear for load leveling bags...
AllBoostNoEco
GA
No, you shouldn’t have anything electronic or electric on your suspension. That only came with the 22” wheels. You could have load-leveling shocks in the rear, but only way to tell is by part number or verifying the build through the window sticker or ETIS. Air suspension was not an option on the 15-17s.
The front suspension is, for all intents and purposes, an identical design to the F-150. The rear is obviously different, but should ride better than an F-150. It’s basically the same style as the front suspension. If it’s wallowing all over the place, I’d give the shocks a bounce test and see if they’re bad.
V
Virgil miranda
New Bedford
what is bounce test
Muddy Bean
We don’t have load leveling bags in the rear...they are nivomat struts if you purchase the option. No bags. Yes they self level. They ride smooth. Check your tire pressure.
V
Virgil miranda
New Bedford
my window sticker says option self load rr lvl suspension
Adieu
SoCal
Push down hard on the right rear 2 times and release. The truck should not continue to bounce. If it does you need new shocks. Repeat on the left.
False, not on expy
Just jump up and down in a corner seat and see how it reacts
Adieu
SoCal
i jumped on the running board till it bounced then jumped off it definitely bounced more than once
Yeah suspension is a bit less than optimal then
Depends how many times and how far it bounces though...
PS dont jump on the running board, that had its own sag and can potentially screw it up
V
Virgil miranda
New Bedford
i tried pushing down on it not big enough or strong enough thats y i bounced on running board wats best way do fronts and rears. how can i tell if load leveling shocks are working
Adieu
SoCal
Just bounce on a seat or door sill
Pushing on bumpers is more likely to screw things up
No members online now.
Landsbutter
