bigcat203
Im still having problems with my Expy. I dont know what else to do. I have started over from the basics. I have ohm'ed and volt tested every sensor(metered values coinside with the values listed in the Chiltons manual), but the knock sensor. I was not able to conduct a compression test, and it does not sound like there is vavle train interferance. I have replaced the TPS, DPFE, Coolant sensor and theremostat,pcv, all 8 new injectors, all 8 new COPs ohmd pri 1.2 and sec 6500, and 8 new plugs gapped at .52. I have Inspected the pcv elbows,cleaned the MAF, IAC, and ATS. I cleaned the grounds and greased every electric connection. I wrapped tape around the intake hose to stop, if any unmetered air from getting in. After all this I still have a stumble and no power under 2000 rpms in any gear, and get a occasionally misfire in the 300's. I get a constant P1151 and P1131 code. I changed to O2 sensors(put new one upstream on bank2, put the bank2 in upstream bank 1 to see if code changes) still get P1151. After 2000 rpms it runs like there almost nothing wrong. Anyone please help this has been gooing on for a month now.
