Here you go
TSB # 04-17-07
FORD: 2003-2004 Expedition
ISSUE:
Some 2003-2004 Expedition XLT vehicles, (excluding Eddie Bauer models), built 2/1/2003 to 12/31/2003 may exhibit the front and rear exterior door trim and fender extension moldings (cladding) fading.
ACTION:
Replace all cladding on all four (4) doors and fender extensions. All cladding supplied in the Service Kit must be installed to prevent color mismatch and continued fading.
SERVICE PROCEDURE
Clean off the area below the character line and above the cladding. Remove dirt as necessary.
Apply protective tape (minimum width 1") directly above the molding. This will prevent scratches when moving the tool along the cladding to release (pop up) the cladding retaining clips.
NOTE: PAINTING WILL NOT BE APPROVED FOR THIS REPAIR.
Using Trim Removal Tool (OTC-4489), open the door and begin to pop up the nine (9) retaining clips across the top of the cladding and the four (4) across the bottom. Once the cladding has been removed from the body, remove the protective tape.
Install the new part (retaining clips are included on the new part). Repeat the repair on the remaining doors.
Remove the two (2) screws that attach the fender extensions.
NOTE: RETAIN THE SCREWS AS THEY WILL BE REUSED.
Install the new fender extensions reusing the original screws.
Return the vehicle to the customer.
PART NUMBER PART NAME
4L1Z-78465K00-AAA Medium Dark Platinum Cladding Kit
3L1Z-78465K00-AAB Medium Platinum Cladding Kit
3L1Z-78465K00-AAA Medium Titanium Cladding Kit
