i'm stuck in 4hi...bad switch?
bigmax88
tennessee
last night i used the 4 wheel drive in my 98 expy(my switch reads 2hi a4wd 4hi and 4lo) i put it in 4 hi and instead it went to a4wd and the light on the dash flickered between a4wd and 4hi really fast about 20 times and then stayed in 4hi. no matter what i select it stays in 4 hi. and says 4x4 on the dash even when i select something else almost like the switch is dead. it has flickered like that before from a4wd to 4x4 really fast a few times but it always came out. so is it my switch or the motor on the transfer case? if it was the motor i dont think the light on the dash would flicker like that would it?
one more question, can i drive in 4 high at any speed? becasue i have been driving like this and it seems to be fine driving in 4 hi and the owner manual doesnt say any thing about traveling at reduced speeds.
tonydiv
technical advisor
Middle River, MD
That sure sounds like a trasnfer case motor gone bad.
If you bang on the t-case motor a little bit and then get in, start it, and let the vehicle roll slightly while in neutral, you may be able to get it to go back in to 2wd.
B
bigmax88
tennessee
does the dash light work from the switch or the motor? why would it flicker like that, like its spazzin out
nvycrmn
Springville, IA
i agree, sounds like the motor is bad. if you are stuck in 4h, i wouldnt recommend over 50-60mph. you can run that speed and shouldnt have any problems but i def dont suggest running 80mph on the highway! quick way to burn out tranny. you cant even get it back in 2wd while in neutral? what i used to have to do in my chevy is put it in neutral, switch to 2wd or 4wd, put in reverse to engage it, then i could drive. maybe try that.
B
bigmax88
tennessee
yea man i tried all the tricks, it just wont go back. ill probably get a new motor, but i know that as soon as i do it will be a bad switch instead, lol
nvycrmn
Springville, IA
hahah, yeah, thats the way it goes!. maybe you should try the switch first. a little cheaper that way. could just be a short (fingers crossed). you can find the part on craigslist or ebay for pretty cheap. try that and if that doesn work, then go with the motor. if you have a buddy close with the same truck, just try switching his into yours as a tester. just my opinion.
