Im going to lay some chemistry on you here, Most of what gasoline is Hydrocarbons, which breaks down into propane, methyl-butane, benzene, etc and then there is our good friend Octane C8H18! you need 1 o2 molecule for every carbon and 1 for every 4 hydrogens. the more abundant Carbon and Hydrogen are the more oxygen is burned, the more oxygen thats burned the less fuel is needed to burn that Oxygen.So 93-104 octane fuels (though alchohol enhanced) use the same amount of oxygen with less fuel, thusly increasing your gas mileage. At $2.40 a gallon vs $2.60 a gallon you'll need to see about 1-2 mpg increase to really save more than a few dollars a year potentially even lose a few in the long run if you average about 10000-12000 miles a year, but If prices were back in the $3 and $4 range half a mile per gallon could save you 75-500 bucks a year with those same gains in the 10-13 mpg range. I averaged between .8 and 4 mpg better when I had a premium tune this summer compared to "mileage XS" for winter so those sorts of gains are possible. But understand more fuel is needed the colder it gets because of the dencer air and awd comes into the factor sometimes so 4 isn't a completly realistic #.
Black Exhaust - do you think that the K&N 56 upgrade is worth the HP gains? Any MPG gains? I'm looking to use mine for some light duty towing and mostly family hauling around. 70% of the time I'll be solo driving - 30% with family of 6....
Other option is K&N drop in filter. Since the truck is new (picking it up on Sat as new 2010 Expy Limited model) should I wait on the K&N 56 until the truck is broken in to see if any warranty issues? They tried to give me heck with my K&N drop in on my 07 Explorer at 10k miles went the MAF sensor went bad saying it was my fault.
What would you do?
Thanks,
AndyGJ
