inner fender rubber baffle/curtain
brilis
NJ
Hey guys, I had the passenger side exhaust manifold replaced by a local exhaust shop, came recommended. In the process, he tore a section off my inner fender rubber baffle type curtain. Not sure what you call it.
It is held on with those black plastic type fasteners, like maybe 5 of them. Anyway I was wondering what that part was called and besides a junk yard where to get one. Searched Ebay with no luck.
Thanks.
B
brilis
NJ
I think the part is called wheel well splash apron. I have seen people make them out of heavy rubber, cut them to fit and then put on trim panel retainers. Also has anyone used any type of after market wheel well type insert?
Thanks.
Newport News, VA
u can always go to the dealership...not a part that will be on hand...also try in the vendor section with A1 Rock Auto
toms89
technical advisor
MD
Do a search on inner fender liner for your year expedition.
LandOfLincoln
Wheel well liner or fender liner should return some results. I had been on lookout for an inexpensive used one for the LH side for some time, but think I might just make my own like the other guy suggested. The cheapest I've seen was close to $50, too much for me!
Flexpedition
midwest
If you only need 5, any auto parts store will have them. Many names like plastic rivits, push pins, body fastener, etc. Dorman is a generic brand that O'Reilly's and Autozone usually carry. If you need a lot, ebay is a better source. They come in MANY lengths and diameters, both the male & female side - so find one you have and either measure it or take it to the parts counter to make sure you get the right ones..
Many wheel well liners also have a Christmas tree or two.
See dormans website here:
http://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=panel+retainers
B
brilis
NJ
Lots of great info
Thanks for all the info.
I have been searching all day hah. Ford tells me it is part of the entire wheel well, need to buy both. $135.00. A footnote says so.
Part 16103. Would love to find just that part, not the inner well.
