Bedrck47
If you look at print 13-05 and trace the circuit you will see the power goes thru C211 the goes to both the door motor and the VSM since you didn't have power at C510 I would assume that you don't have power at pin 1 of C2113b at the VSM
When you installed the jumper you then had power to the door motor which shows a open circuit.
If you were to install a jumper from C211 pin 7 to C2113b pin 1 That would give you the 12V to the VSM and then the other circuits may work unless there is another problem elsewhere
Check back in the morning for some information as to what to do next
