Install headrest video
Discussion in 'Audio & Electronics' started by K_Flave, May 23, 2019.
  1. K_Flave
    K_Flave New Member
    35
    May 23, 2019
    California
    I have a 2019 expedition and I am trying to install a rear seat entertainment system in the headrests. From searching it sounds like I need connect to 12v switched power supply, but I am unsure how/where the best place to do this is. The connection that comes with the unit looks like it plugs in somewhere, but most of the videos I have seen have people splicing and connecting the wires. Any thoughts or suggestions would be much appreciated. I included a picture of the connectors that come from the entertainment system that should connect to the car somewhere.
  2. aagitch
    aagitch Active Member
    46
    30
    Mar 6, 2019
    Paris, KY
    Is that factory or aftermarket headrest system?
  3. stamp11127
    stamp11127 Super Moderator Staff Member
    61
    5,818
    1,066
    Mar 10, 2012
    Temple, Georgia
    The 2019 wiring diagrams are not available to me online now. I'm looking at the 2018 which are, which trim model is your Expy? You may be able to install a branch circuit off the driver seat module. Just need to know what you have in order to compare the diagrams to hopefully what you have.
    The 2018 shows a "Family Entertainment Relay" that is "hot in run". Unfortunately the software doesn't show component locations of that relay. Your local dealer may be able to help with that.
  4. K_Flave
    K_Flave New Member
    35
    May 23, 2019
    California
    This is an aftermarket headrest system: Audiovox HR8. Its a 2019 Platinum model expedition. Couldnt find any that had the towing package and rear entertainment, so i thought i would take a shot at installing the RSE myself. That would be great if there is already a switched power supply. otherwise there is a 12V cigarette lighter outlet in the center console that looks reasonable to access using some T-tap quick connectors. it appears to be switched. The only potential issue I could see with the drivers seat module is that is always "hot," even with the ignition off, so the RSE could be in use when the ignition is off and kill the battery, which my kids would undoubtedly do.
  5. aagitch
    46
    30
    Mar 6, 2019
    Paris, KY
    Although mine is a '17, I used a fuse tap at the interior fuse box. Switched power
  6. Roger98gt
    Roger98gt New Member
    37
    Thursday
    Chillicothe Ohio
    Mine is a 17.Are all the fuses on inside fuse box switched ?
  7. Black
    Black Full Access Members
    36
    999
    428
    Mar 26, 2018
    Kentucky
    Which fuse did you use that was switched?
  8. aagitch
    46
    30
    Mar 6, 2019
    Paris, KY
    The radio fuse. I used a fuse tap from auto parts store. My headrest dvd's only have power when in "acc" or "on"
  9. aagitch
    46
    30
    Mar 6, 2019
    Paris, KY
    I discovered with a voltmeter that most of the interior fuses were constant power. I finally realized that since the radio only runs in acc and "on" that the fuse for it must be switched.
  10. Black
    36
    999
    428
    Mar 26, 2018
    Kentucky
    But the radio will run with the key in the off position granted only for a short period of time or until the door is opened.
Share This Page
