Installed Bilstein 5100's - thoughts, impressions, lessons learned
tri650
St. Louis, MO
I was not a fan of the stock suspension on my 17 Ford Expedition Limited. Had a few ass puckering moments going over rough pavement and decided to upgrade to Bilstein 5100's, based on opinions on this site. I decided to take on this project myself as it looked so easy on the youtube video's. Here is what I learned:
- Youtube video's lie: I watched a number of youtube video's on changing out the struts on my Exp and they made it look so easy. Not so. Compressing the springs - to take off and then mount on 5100's - was a major pain in the ass. I admit I did not have an industrial strength compressor, but it took forever to compress the springs. Not the 2 minutes they show on the videos. Getting things aligned, then keeping them in place was also painful. I bet I spent 75% of my time ******* around with the springs. You can get spring compressors at Auto Zone, etc., for free to use and return.
- Bribe a friend or family member to help: I did this by myself. Having another set of hands would have saved a lot of time and effort. Plus, I could have used someone to calm me down and stop me from throwing a wrench through garage window (did not happen but had it cocked and ready to throw)
- I wasn't crazy about the build quality on the struts. One shelf (stock setting) for the spring clip chipped and would not hold the lower spring holder. Had to get a new strut. Not sure if this is aluminum or not but surprised it shipped so easily.
- I did not do a great job of measuring. The new struts, with clip in "stock" position , raised the rear by about 2.5-3". I put the clip on the front struts to "stock" and I was at least 2.5" - 3" higher in the rear. It looked odd. I wished they would have made some mention that the 5100's are longer on the product description.
- I decided I would just add a lift kit to the front as opposed to going back in and disassembling the front strut again to change the spring clip to a higher setting. At this point I was worn out and could not see myself digging into the whole spring compressing thing again. Sorry, but at 70 years of age the body just doesn't like all of that physical activity anymore. Even with the 2" lift kit it still is not level. Back end is still higher, but probably I am the only one that will notice.
- With the additional lift I barely makes it into my garage. In fact, if I raise the tailgate with it it parked in the garage it hits the garage door and wants to bounce back. Something I did not consider. If I add bigger tires I will need to remove the top luggage rack to get it into the garage.
- Would I do it myself again?: Hell no. Way to physical for this old man. Only exception is if I had help.
- The ride: After all of this work I would say it was worth it. Previously I would bounce off bumps and the suspension would wallow over big bumps. I would lose contact with any rough surface. I had a few moments where the back end decided to move on its own when I went over anything with a washboard surface. I now absorb the bumps and don't lose contact with the road. It is definitely stiffer, so you feel the bumps but you still stay connected to the road. Even my wife commented how much smoother the ride is after a 350 mile trip.
- Other thoughts: Now that it is raised I need some new tires and wheels. Stock wheels look puny when you look at the space I now have with it lifted. Falken Wildpeak or Milestar Patagonia have been recommended. Pricey but worth it.
I understand that by publishing this I am opening myself to ridicule and mockery. I accept my fate. Bring it on.
I'll add some pics this week.
Alwaysthinkin
Army
Georgia
No ridicule and mockery from me. I appreciate your desire to do the project yourself and understand things aren't always as easy or straight forward as it seems for others. Personally, it always seems to take me 3 to 5 times as long to do something as described by others. Your description of your experience is sure to help someone else down the road and, personally, I appreciate your thread and your willingness to put yourself out there. Of course, I suppose my being 70 also is part of my appreciation for your doing the work yourself!
JasonH
Houston, TX
Compressing springs can definitely be a chore if you don't have a good compressor. At least you didn't replicate my error. The first time I did struts, back in the early 2000s, I put some Eibachs on my Accord. Only I reversed the springs and put the rears in the front. That was an (unpleasant) learning experience. The rate was way too low up front so I scraped everything until I was able to have a shop swap them.
tlahnala
michigan
I like the look of K03’s on my ‘15. Just finished an 11,000 road trip with them. A little noisy but nice.
EngineerMike
ca
Bilstein 5100's are ONLY if you have a lift condition. They are the same shock as the 4600, but the corresponding 4600 will come w/stock ride height.
I changed the suspension on my Nissan P.U. from stock to 4600's, and saying nothing to my wife, she called from the road to ask "what did you do to the truck, it drives wonderfully." Going to swap rear shox on Expy to 4600's.
rolandus
Wisconsin
Looking to do something like this myself, but if I did, it would be with the 4600's. I'm just paranoid about trying to reuse the same springs and mounts, because this is a 2010 with 180k miles, and I'd imagined they're not only worn out, but as rusty as get out. I see some Rancho QuickLift coilovers for sale, and it's tempting. Does anyone have experience with those? I'm not really going to be off-roading, but my current shocks are so bad that I'm losing ground contact on small bumps, as the op said.
rolandus
Wisconsin
Timm1687
Atlanta, GA
I know this is an old post but wanted to add my take with the Bilsteins.
My goal was to keep it stock height.
Bilstein 5100 Rake Results – 2017 Expedition (Non-EL)
Installed Bilstein 5100s with factory springs.
Perch settings:
  • Front: Middle clip (Bilstein recommended)
  • Rear: Bottom clip (lowest)
Fender heights (ground to lip):
  • Front: 36 1/4” (L) / 36 7/8” (R)
  • Rear: 35 1/2” (L) / 34 3/4” (R)
Result:
~1.5–2” reverse rake. Rides well and feels great, but visually the front sits noticeably higher.
Planning to wait a bit to see if the rear settles before adjusting perch height.
The install manual calls for the middle perch setting in the front and lowest in the back for stock height and an trying to figure out if that is my problem
spav8r
Pennsylvania
Did you end up figuring this out? I just ordered a set and will be doing this job soon myself.
RaginTxn
US
I have a '17 Platinum and also interested in the 5100 option. However, with the rear leveling and CCD, I'm wondering if it's just getting Limited strut mounts front and rear, and then building with the 5100s? dunno if anyone has tackled this? this is the closest post I could find with the search
Rodewaryer
Montana or Arizona
You aren't alone. 99% of the time the quoted time to do a task is as you said, 'at least' 3 times shorter or more than the time it took me. Granted, I'm OCD, but that just means I'm careful and not sloppy about how I work. This habitual lying about the time it takes to do a job is pathetic and even if it's not a lie, someone is generalizing and leaving a lot out of their estimates.
justbecause
alabama
Perch settings:
Result:
how is it now, did you go back and adjust the rear?
my 15 has 170k miles I really want new shocks before our big trip. but this week shes getting new exhaust manifolds and turbos so I'm just at home thinking about all the work I need to do before I hook up 4500lbs and head off across most of the whole country.
